- Reading, PA
Not sure what speed plate this is but it does not have cuts for orings on the bottom. Kinda annoying because I have to use carb gaskets and cut the bolt hole tabs to fit.
Engine is 66E 927. The manifolds are wdk twin. Carbs are full spec 49s.
Wondering if anyone had one already cut for 49s they'd part with? Or if a machinist could cut recesses for orings?
