- Virginia Beach, VA
You can do that in public? Your g/f sounds like a keeper! :haha:
Definitely a keeper:biggthumpup:
Now if you turn left and lean the ski left (until the pump is just about to let loose) then unwieght your ski, throttle down (to pop the pump out of the water for just a flash) then you turn the bars the other way and gas it just as your pump hooks back up. Wooosh you can shoot water for 50' no problem and ride away without even slowing down much.
I tried this several times yesterday and I got nothing. I need some more explaining. I was just trying to go moderate speed and lean the ski over one and start to turn then crank the bars real hard the other way. nothing.
You can also just press really hard with one foot in the front of the tray while pushing down on the handpole. It will also pull the pump out of the water.
Doug
A good way to practice on a lake (when traffic is low) is to ride about 30 feet out from the edge of a "no wake" zone with a lot of buoys and try to target them. The no wake zone at my lake has about 8 buoys spaced 100 feet apart.
I can't do this well, but I was practicing this week after reading this thread.
i get a sliding turn going right before the pump hooks up i crank the bars and give her a good brap and i get a little spray. maybe 10 feet right above the water.
i would like to see some sequence pics or some vid of this.
i have been trying this the last few times i went to the lake.
i get a sliding turn going right before the pump hooks up i crank the bars and give her a good brap and i get a little spray. maybe 10 feet right above the water. afterwards i usually fall or end up in a tail stand.
Don't slide !!! Just a quick lean/hop/whip the bars and brap ! The farther you lean the higher the spray ! Just go back and look at your pump.. check out what is going on when you lean right and turn left.. Once you see whats going on you can get it to work !
ok fne.. a very easy way is this.. at the beach/lake edge wast deep in water.. stick your knee under your ski (left side)and lift the back end out (like a racer would do wth no holder) start it up and let it idle.. turn the bars to the right.. it will start squirting.. the more you lean the higher it will squirt !
