- Greece
On my square when I removed the factory foam in the gunwale it popped back to 'almost' normal. Still a very very slight indent, but before that it was a dent you could have eaten soup out of.
You are lucky because mine seems to have elasticity and pops back in
First, I opened a hole of 12 cm on the inside gunwale. The foam is bone dry by the way ! (see pic)
Then i tried with a wood log to hit it hard outwards, but it acts like a spring and comes back in.
Then I tried pushing it out with an hydraulic jack (but this stupid jack only works upright
So i pulled out an old mechanical jack and pushed the wall out successfully (i could even hear the foam detaching )
Unfortunately when i unscrew the jack the gunwale came back to square 1 (sucked in position)
