FX-1 "St.Augustine surf slayer" new pics,i finally tufed it!
butti
lone wolf
F-XTC
notice there are no pix of that!
I guess a complete carbon job would detract from your fancy paintjob and topnotch glassing skillz
:nana: :nana: :nana: :nana: :nana: :nana: :nana: :nana: :nana: :nana: :nana: :nana: :nana: :nana: :nana:
(now, its 2 on 1!)
no pics of the inside,its shamefull in there
This is going to be SICK!! Nice work. I can't wait to have a fixed steer yamaha. I LOVE those gunwhales/holds, looks killer.
butti
lone wolf
F-XTC
So you run smaller id. bearings in the SJ housing, and different seals?
i press fit the whole core of a kawi mid bearing into a yamaha housing.one or both parts need to be machined to make it work.
if someone were to find the right bearings and seals to pull it off witout machine work they would a :):):):)ing hero to many im sure!
Its been done.
No secret.
It was in my build thread.
Seals I'm using Timken 100115977. Size 20x52x7. They are double lip seals with a spring on one lip. I can't find the number for the bearing but it was similar to one found in McMaster-Carr. #5972K56. Its double sealed and can spin up to 9000 rpm.
Bearings have the same slip fit on the driveshaft as the stock kawi, and same press fit in the yam housing as stock yam bearings.
Only problem is neither is stainless. I just looked at the spring on the seal and it is rusting. Bearings still seem fine.
I've only put about 20 hours on this setup 4 hours of which in the salt.
WAB
salty nuts
coastal GA
I missed this bofore somehow.
Awsome project! I love it
I had the site bookmarked that showed the visser pole support setup. You gonna weld up an alum support for the pole similar to that?
butti
lone wolf
F-XTC
post the link,i havnt actually seen that ski in a long time.im not sure how im gonna do this one yet.i have been kicking around a lot of ideas.i want to keep it convertable so it can be ridden as a pole ski sometimes
butti
lone wolf
F-XTC
shes in primer!
i have hok candy purple for the bottom and the pole.i was planning to do the topdeck and hood white..but i just stumbled on some black leftover from the "rusty" build that would prolly look great with the sweet tart purple.
option three is silver as its the basecoat for the candy purple so i already have that too
now im totally confused:banghead:
