- amarillo ,tx
Dnt look to bad could still b locked up
something can test out fine with ohm test, but still fail under load. Voltage drop test will tell you in an instant.Get a nice digital Multimeter that can measure volts, Ohms, etc... Ohm the out of everything. You have no idea how usefull having an Ohm meter is. It'll tell you if you have a weak ground instantly.
Check and clean grounds and or replace cables. My guess is you have a cable that's crusty or cracked on the inside.
