Custom/Hybrid steve-uk wcf carbon kevlar - team scream ss865
steve-uk
Manners cost nothing
Barrie - ontario
So here it is.. another build it seems!
updated specs
WCF '08 based Carbon Kevlar Hull (Lucas you are the man!!) with TEM modified nose
RRP Pole
RRP Dual Breather lowered pole bracket
Team Scream assembled SS 865
with Team scream dual modified 46s
Boyseen Intake and reeds
Team scream port matched limited b-pipe with stinger mod
TBM Flywheel
OEM Water Box
550 Gas Tank
Electronics will be MSD Enhancer
running lightened flywheel untill i can save some $$ for a tbm
144mm OEM pump running 14/19 Prop and tbm cone
Worx '08 Grate
Plate - not decided yet
Thrust Trim system
Thats the specs so far.. will post pics once i get into it
big props go out to team canada for bringing all my parts back from daytona and to josh and lucas...
spring cant come quick enough!!!!!!!
:cheer2:
steve-uk
Barrie - ontario
picture.php
junkyardj
┌∩┐(◣_◢)┌∩┐
no problem bringin it back for you bro! im glad you got it! pat and all the boys at team scream worked really hard to work all this out for you and we cant forget josh and lucas for helping put us all together
word to the wise for everyone out there dont ride any of josh's sk's unless you want to buy one of these seriously this stuff is dialed in!
Aircraftsalz
Thrust built Dasa Power
Off site
Congrats Guys, We couldn't let you guys stay in the dark much longer. Your going to love the Xscream package. You should have seen JC's face the first day he rode a ski with some dialed in Brap!
The smile was priceless!
Lucaumpits
RIDE LIKE U'VE STOLE IT!!
Orlando, FL
Steve is all good
I hope next year u got chance to come here,
you going to freak out with that set up!
I'm so glad that you like, I just didn't had the chance to glue the turf back on the sides of the rail I'm really sorry about that,
let me know how it goes
all your crew they are crazy awesome
I cant wait to see this
braaap
steve-uk
Barrie - ontario
thanks lucas... i spent some time with some wax on the hull today so its extra shiny
the only problem i will have is turfing the side rails where the turf was removed for paint as its the square pattern hydroturf... dont have any and hydroturf dont offer it.. so it may end up with a new turf job by the time im done
i like the nose mod.. not so sure how i add a tow loop on the front now tho.. lol.. maybe i should add the metal tow loop bracket on like the rickers although im not sure how they are attached..
josh maybe you could take a picture of that and post it up so i can work out how to do it
Lucaumpits
Orlando, FL
I can send you a piece to finish the rails,
u do the just like Jetmaniac and I did, and the inside put a little plate like 1'' by 2''
and you are all set
check it out
really? that was the size prop pat told me to go with....
well Pat is the pumpmaster so definately a good start
just relaying an experience....the motor I ran was a ported 760, like all kinds of wierd race and f/s porting..very strong motor ran on a single 48
I had a 140 setback 12 vein mag with WW short cone and that motor made good use of it...the thing was so freaking faaaaaaaaaast..
rediculous fast and neck snapping hookup..even in the whitewash
steve-uk
Barrie - ontario
updated spec... was flopping backwards and forwards with 140 mag pump, after talking to pat at TS decided that it would be a safer option to go OEM pump with tbm cone and 14/19 prop
this gives me more options, maybe later in the year i will be able to afford a 144 mag .. we will see
also decided to drop the $$ on a tbm flywheel
realised i hadnt posted pics of the hull yet.. so here it is.. not really moved to far forward as i need to wait for parts to arrive so i can crack on
picture.php
