this was how she ended up
ok so following probably my longest build in history its time to do it all again....
it took some time to get used to but in the end i loved my rok
this year its getting some more power
Jetworks
- 820cc Big Bore Stroker
- billet 6 mil crank
- 84mm pistons
- ADA girdled head
changing from a single 48 to Dual ATP 48MM Annular discharge carbs, havent decided on a boyseen reed set up or r&d intake with VF2s
will be running the ATP Flame again, was the first time i have ran T/L and even on a 718 the gain was huge
i would like to reposition the battery as once dual carbs are on i cant access the battery
also am throwing around which tank to use, i have found a tank that i think will work but it has a sump and it seems no one can tell me if thats a good or bad thing
finally the main change i need to make is the intake grate, i currently have the modified stock sxr intake grate.. which .. frankly ... sucks.... so i want to run the atp adjustable intake grate, to do this i either modify the pump tunnel or make an adaptor plate
i have been throwing around the idea of a 148 mag but as when i did that before everyone seems to think its too much pump... i have enough to spend my $$ on right now so i guess we will see on that one
