strap on....
Y
yamaslut
Guest
Do you have room for your feet to be out of the holds and straps?
what you see is what you get.... I'll see how it effects "leg flailing tricks"
I do most of that in front of where that strap is at...
W
wydopen
Guest
this is how I have been considering doing up my new hull......
the other option is 2 straps, and full channels front to back.....like JK's camo boat
thats my plan on my new rn but they had to do a custom carbon exhaust tube for that one..ill probally just channel the backs cause i like my toe farther over in the tray..im telling you man.ditch that hold in the front,strap in and you will never want to ride anyother way..just try it..its easy enough to switch back
thats my plan on my new rn but they had to do a custom carbon exhaust tube for that one..im telling you man.ditch that hold in the front,strap in and you will never want to ride anyother way..just try it..its easy enough to switch back
i dont use a front hold...
i use a right rear foothold and front strap ONLY....I stay locked in 100% of the time as well...
(my avatar is with NO straps and NO holds)
W
wydopen
Guest
nice!!..i fyou dont jump in the holds then why not use a strap..then you can get a little more sideways in the tray which i think helps..my strap is mounted so my toes are inside the footwell but my foot is more sideways then it would be if it was in the hold, if that makes sense
Y
yamaslut
Guest
is there any reason not to make your whole tray wider? I know you widened the bottom of yours slutty. it's got me thinking.
it's one of the best mods I have ever done.... really makes carving more stable
that stab was actually pretty scary....it wasnt very big but I felt all loosey goosey in the tray
i go front strap for the left....back right in the hold with my foot perpendicular to the hull
so, I stand almost completely sideways just like you said....
Y
yamaslut
Guest
What's everyones opinion on mounting positions of 2 straps for rec riding?
I'm trying to do my homework. Looks like blowsion is the place to get the straps?
ya got to kinda figure out what works for you
W
wydopen
Guest
ive moved mine twice and im gonna move them again...
Y
yamaslut
Guest
the one I put on ripped off in 10 minutes... I did it twice before w/ no problems... go figure..
I think I will get another strap and try again...
W
wydopen
Guest
yeah... that was my worst work yet...
he he he....
guess that's what happens when you do ******** half ass..
oxnard111 tried it as well and it didnt work..it lasted about 5 minutes...im gonna glass in an aluminum plate on my new ski and screw into that
i dont know how you got it to stick before??..better prep?...more filler??
Y
yamaslut
Guest
not sure... the plate is the way to go!!!!!!!
