My motors went the entire season of racing, 7800 plus, being loaded in turns and run ragged by me. I'd be willing to bet I put more, harder time on a motor in a year when I was racing than a freerider does in 4 years. It's a heck of a lot harder on a motor to load in the turns than it is to jump waves or blip to do a trick. That's why detonation is such an issue with race skis. That's why you guys can run 195lbs on pump gas and not destroy piston crowns. Even still, the only maintenance we did to our motors was one top end in March, one top end before Nationals and a crank rebuild every other season.
I have ridden pump gas set ups that would blow away most on this forum. Again, it comes to set up and the entire package.
The trick is to set up the ski to get the desired result. It's funny how the billet DASA motors have very similar port timing to the race motors from 10 years ago. Those same motors that some people say have no bottom end. Perfect example is our spec motors. 99% of the people on this forum will tell you a 61x cylinder is better for bottom end than a 62t because the 62t has higher port timing. This is not true. If you prop the 62t to get to the right window of rpm, it will always hit harder and pull better. Proof? Look at all the fastest sport spec blasters. They are all 62t set ups.
Set up has more to do with any package than what stroke, bore, color, flux capacitor, etc. any ski has. And, if you are talking about freeriding and surf, the MOST important thing is nuts. Zimmy goes bigger, higher and crazier than just about everyone out there and until recently, was rocking a 650.
IMO, the best set up for the budget minded rider is a TPE stock stroke, ninya pipe, some 46s and some timing. I've ridden that set up and it is more than most would ever need in a freeride ski.
If money is no object, and there are a lot of guys on this forum who act that way, then by all means, knock yourself out, go 10 mil, 16mm, whatever.
SM
