- Oceanside, CA
tried that but to no avail........and i would be really pissed if i broke it.......
drill the bolt w/ a drill bit that is almost as big as the width of the shaft of the bolt and then chisel out the rest or break it off there w/ a hammer after it's weak. then after you have the manifold off, grind the bolt flush if you can't extract it w/ vise grips. After that, drill a hole in the center of the bolt and remove it w/ an easy out...
:Thinkingof_:
we did that method on my buddies..now he has broken easyout in this cyl..he has actually been running it for over a year with one bolt short haha
Mine are DEF 12mm i remember making my specialty manifold wrench. 12mm open end + grinder lol
Take all the other bolts out and beat that bitch down with a rubber hammer. :smashfreakB:
and if this fails.......get a bigger hammer, duh!
