- Texas
That made absolutely no sense at all....
My bad. Lost phone on ocean in a bag. Tracked it from some random persons phone. Learned it was with friends a mile out on the ocean. Learned I'm not good at telling stories.
RIP NATION BABY!If your tray and bulkhead and lines aren't perfectly sealed
Converting a RIP to a bulkhead design would be a pain in the ass to begin with.. Would have to change all the thru hull tubes and create your own bulkhead. No thanks.RIP NATION BABY!
Scuppers aren't necessary. My ski can be upside down for a few seconds and not take on any water.I suppose, but seems having a sealed tray with foam and using scuppers would be a safer option. With limited downside.
Oh, I'd never use scuppers either. For me, sealed tray with foam and two bilges is the only way. I also don't want to fool with shoving a bunch of crap inside my hull and worrying about pulling it out every time I want to take something apart, or worry about it coming loose and getting tangled in the driveline. But, to each their own!
I have thought about installing a bilge but the way the hull is it puts water to the back of the hull anyways. I may just get a bilge kit but haven't made that step yet. Right now things are in small water areas so haven't put too much thought into it. have to test the scuppers in the water and see how much they let pastWe'll see if you feel the same way in the even something goes wrong and your ski goes down
Im going to be running scuppers this next season and a bit worried about it. Luckily my lake is small and only 5 feet deep. No foam and no bilges. I might try to put some noddles in the back if im able to tho. If I go to a deeper lake I will have a retriever or something close to that in the tray so if I go down I have some rope close by
