mike b
- California
@paczowski123 yeah Ill probably have a bilge kit setup but would only be used if she was sinking or just flooded with water
If you set them up right, you don't have to worry about it. If I rode surf all the time it would be setup much different. But since most of my riding is done at the lake, the chances of losing a ski are slim.
If I'm riding mine are switched on 100% of the time, that way as soon as water gets inside its on its way out. Also, if I was to get separated from the ski and unable to get to the switch, or the lanyard breaks and the ski runs away, they are running as well. I'm a big prepare for the worst kinda person as mentioned.
I can tell. You're freaking people out now we are buying retrievers and bilge kits lol. Im now nervous and my lake is only 5 feet deep. But that one time i go to a deeper lake ill be nervous as poop now unless i do the bilge. Might as well epoxy a basket down at the very least so when I hit the big lakes I don't have to wrench the night before installing the bilge
No foam, no bilge, scupper...... yolo!
Finally, someone with some common sense!
I'm just the crazy one. Take a brand new hull, with all the goodies, first ride in the surf....... no bilge, no foam, no retriever, nothing.....
I've thought about putting a dab of silicon and mashing these to wherever I want in the hull. Take my scupper out and throw a bunch of these in there. Make something to where they can't clog the scupper. Put some in the hood so I have a floating hood. I think about this stuff on long drives.
http://www.amazon.com/Pillows-Gallons-Cushioning-Packaging-prefilled/dp/B00KO3F6H0/ref=pd_sim_229_4?ie=UTF8&dpID=41ofqYyPBfL&dpSrc=sims&preST=_AC_UL160_SR160,160_&refRID=1GZF3J8NS6R7426RA982
R.I.P. Rip any luck finding it?
Air blair cell
where do u find these ones u speak of, I found these mechanical ones and use to have an electronic one yrs ago..Just run a seals electronic float switch(no moving parts), they last forever and you never have to remember to turn on your pumps. Running your pumps all day puts un-needed stress on your charging system.
