stanton
High on jetskis.
- atascadero,ca
dont install a versiplug or anything that you cant close while riding, that would make your problem way worse. if i was you id leave it alone or get a super long drill and drill from the back between the chines to make a long hole for any water to drip from the foam through. seal it up with a stainless screw and call it done. its just a hull
