Custom/Hybrid SUPERFREAK talk
tems an amazing rider on the dirt.. way beyond me.. i got around to taking a pic.. kinda cheating since its not rigged and bonded but i will get another when i am finished
So what are you guys running for throttle cables, does the stock RN cable fit, or do you need a SN cable?
Also, I plan to run my 785 engine, with a stock pump. Right now in my SJ, I have a K- impeller. The ski is more mid and top end than low end, partially because I run a sectioned raider chamber. Anyone running a somewhat similar setup and care to share their prop setup?
Fl
Ed , I like the Jetmaniac throttle cable, it take a bit of moding but is super smooth and bomber just spray it down with lube and protect it from chafe , under $30.
Soon to have a polyester/glass ski coming out in 6 weeks, the first proto looks like it will be a real porker at 92lbs ( yes you can say squeal like a pig)
still looking forward to riding this build up at full length,after the ride in the lake,I was really wanting to get some surf time on it,brokin pole,whales and lightning were out to make sure otherwise.lol Any chance you will have one ready for wavedaze?
why no scupper?
Really bad experiences with them in the past. I'd rather do without.
Remember me getting those two stock bilges from you? :biggrin:
Let's see if I can fit at least one of those and a couple of electric pumps in there.
Aircraftsalz
Thrust built Dasa Power
Off site
I put mine in the center on but theres room on the top half of the bulkhead... I just put mine in the middle so my foot stays away from the handle
No, the front! I.E., are you putting separate bolts in, or are you bolting them up with the hood-side hood hooks?
Aircraftsalz
Off site
Also Matt if you look you can see I mounted the Ebox like a FX1 directly to the bulkhead with a little turf. Makes a little more room behind the engine.
Aircraftsalz
Off site
Wait on installing your hood hooks or hull side hooks. Right now I'm moving mine to the middle to help with hood adjustment. I'm at the shop now so give me a few, will post before & after pics
Buckwild12
I'm moved by DASA power!
on mine, I am planning to go underneath the handlepole bracket using the pole bracket bolts to hold it. I have seen a few done like that and it looks super clean.
Sweet, waiting.
