Any thoughts on the following narrative....
I let my 701 ski sit for a couple years (heated inside, properly winterized), I got it out the other day, fired up and ran for about 10 minutes before issues. I noticed it wasn't pissing water thru engine, so pulled up on the beach to investigate. nothing visibly wrong.... Cranked on it, got it running, and engine seemed to fill itself with water and die. Took her home and found the ADA head gaskets / o rings from domes to cylinder head were partially gone on the front side of the rear cylinder. No problem, chalked it up to o rings sitting and getting old..... installed new rings installed, got it running again and it did the same exact thing, front side of rear cylinder o ring is gone. Ski ran good for 5 - 6 minutes, stopped pissing water, bogged down, and done.
It has all the tricks, msd, b pipe, dual 44's, etc
Another question I have... The McMaster carr parts thread,,, some appear to be running oil resistant buna-N o ring cord stock for the outer head seal, part # 9407K21... What do you do with the little gap created by having a non continuous piece? Isn't that a source for water / air to escape and cause issues?
