Super Jet Superjet Lost All power
My wife was riding her ski the other day and fell over. She said it seemed underpowered after she got going again so I jumped on it and it has nothing. If you hold the throttle wide open in just sputters along. I thought maybe she somehow got some water in the gas so I drained the tank, changed the filters, completely disassembled the carbs (everything looked good inside and ski clinic completely rebuilt them last summer). Compression is 150 PSI each jug. Took it out today and same thing. I dont know where to look from here maybe reeds or something going haywire with the ignition.
Any suggestions would be great.
X2 on this, little things inside the pump have a big effect.
Pressure wash the pump and intake area and try again.
Ten four. Visually the pump and intake look clean but maybe it's something I can't see.
I should add that the motor is not revving up at all. Out of water it sounds fine but in water full throttle is what about 1/8th to 1/4 throttle used to be
Dmac80sc
Here
I was just thinking maybe stripped splines but you say it sounds fine out of water?
