schicks
Karma Enforcer
- West Michigan
a ton of ways to make a leak tester. You can use a bike pump (similar to mikuni n/s popoff tester), you can barrow an air regulator from work that use 1/8" line and plug it into the pulse line (i usually use the pulse line to leak test my motors, which only works if you are running a 38 manifold with the cross over which pressurizes front and rear at the same time; if you are running a 44 manifold w/o cross over you need to do front and rear cylinder seperate) To seal off the engine, you can use radiator style plugs available at menards or you can duct tape the manifolds off and use the carb and exhaust manifold to clamp and hold the tape in place to maintain a seal. Only pressurize up to 10-15 psi and go slow when using an aircompressor as a supply.
Also, if you engine block is clean, you can usually see some sort of oily blow by where its leaking.
