- Cleveland, Ohio
The diaphragms looked and felt brand new. I replaced all the fuel and pulse lines and put new plugs in just because. Took to the water and it acted fine for about 1 minute then started the heavy bog.
I then took it back home and sprayed starter fluid around the carbs and base gasket while it was idling and 2 separate times it started to idle higher while I sprayed at the base gasket under the exhaust manifold...?
