piratelife
Frandsen works
- In the hood wood
Are there any other options besides oem. I thought i had seen a aluminum one also...........Any advice would be appreciated :shrug:
Why will you have to order a ripoff OEM shoe?![]()
My rn one is broke...I just dont like going to the local yamaha dealer....Dose someone sell them on the X?
You have three options:
OEM plastic shoe
XR-Tech aluminum
Blowsion/JetDynamics aluminum
I've never done it.
The JD shoe is said to require a lot of grinding to fit.
The XR Tech shoe is supposedly easier, but it sounds like you need to open it up from 140 to 144mm.
The OEM shoe is probably easiest to install.
The JD one doesn´t even remotely fit out of the box. I probably spent 3-4 hours grinding that thing to get it AND the pump to fit. I think R&D makes/used to make one as well?I've never done it.
