swapmeet
Brotastic
- Arlington TX
looks like maybe it had paint inside the hull and that could be why all the glass didnt bond. paint is not glue. smc is not the easiest stuff to bond to. epoxy only.
since you got it all cleaned out inside take a look up at the nose and if you see repairs its a good bet that nose is poorly repaired. if its solid maybe they just cracked the rail and the repair wont be so deep. more cosmetic and weight saving.
if you are going all the way something else to think about too, the bondline usually has a weak spot where the glue is letting water in. you may want to fill and reinforce the perimeter of the hull if you are in it that far.
at least after the fx you have the skills now. look forward to a ride report or a build update.
remember riding>wrenching
Intresting questions. I have answers!
The SMC side of the glass was bare, but the engine side (that the CF laid against) was painted gray. I believe that paint was part of the bonding problem.
I have looked at the nose from the inside and it appeared to be fine, no repairs etc. The stock glue was still sticking out between the decks. I agree that perhaps somebody lawn darted the ski and fixed/ reinforced the nose to stop a future break from happening or fix one that happened.
Concerning the bond line. When it was reinforced, it appears that the green glue has been removed. Unfortuantely whatever was used to replace it did not stick (GASP!!!) and came out with the glass. I was going to wait to put something in its place so that when I did everything, the material used to fill the bond line would make a chemical bond with the fabric layed on the side.
I'm still at a point that I can fill it if ya'll think its better to reinforce it now. My thinking is that I don't ride very hard and i'll probably spend the remainder of this season re-learning how to ride this hull.
Thanks for the feedback Tom.
