So after my first ride, the following day the area above my right ankle was bruised from banging on the foot holds. They were sooooouper loose. I decided that if wanted to increase my level of enjoyment, I needed to tighten them up. I go to investigate, and it turns out all thats covering the holds is a layer of turf..... "Thats weird" I say out loud. I continue to scrape, peel etc. Then I found it....
"REALLLLY?!?!?!?!?, You're just gonna turf over that S?!?!?"
I'm becoming quite suspect of Mr. Brah and his benevolence concerning how delapidated this hull is. Saturday night, I wanted to kick Mr. Brah square in his junk.
FWIW, it appears that the hold itself cracked, not the junction between it and the hull. The aformentioned "BLOWsion" indentification helps quantify my theroy. The rest of the evening I was writing a customer service letter in my head
"Dear Mr. Blowsion, I understand that your V
ERY BUSY (yes i use effing itallics in my head. I'm sarcastic, they're always on) sipping Mojitos in the Maldives on the private island that you purchased with the money made off marking up your shipping, but if you don't mind.... maybe... I dunno, throw an extra layer of glass or two on your GD footholds.
Sincerely... Mr. Effing Swapmeet
P.S. dick "
This hull is just begging me to tear into it, and I won't succumb to its siren call. I had two choices at that point gents. Follow that crack to god knows where, and hope like hell it doesn't get worse and then fix it and start my padding and turfing.
I did not choose this route. I know my tendencies, i'd be up until 3 am, the tray would be on the ground and i'd be pisssssssed......
I'm sure this will evoque some varied responses, but I choose to just turf over it and ride. I'll handle that issue when I handle everything else. Call me lazy (i'm not). Call me impatient (Very much so.)
This is my first go padding a foot hold and all I had was 9mil black pad, which i'm a fan of. I quickly realized I didn't know what I was doing but I think I did alright for my first try.
I ride surf stance, so I didn't tackle the left hold. God knows what lurks below the turf on that side.
I removed the foot strap. It was installed with one screw on each side, which caused it to flop the way it is in previous pics. I was honestly suprised to find a threaded inserts in the tray. I figured it would be a drywall screw and elephant semen holding it in. I filled the holes with some clear silicone. Once again, i'll deal with it later.
Little down low tray shot. Shows the difference between the two sides. I'm pretty happy with my splice job. Had to make a seam on the turf. Impatience... it happens.
I flush cut and D-cut my protec plate. No after photos, but some in process ones. I'm like a mad fabricator!!!
On the lighter side of things (which is where I try to stay)... a member of the local peanut gallery (and heckler) Mr. KotaJoe burnt through engine number 3 or 4 for the season recently and is throwing a 61X in his SJ (poor engine, it doesn't have a chance). He needed to borrow a 140 Main jet from my expansive Jet inventory, which I was happy to loan him. I was going to be out with the family so I agreed to tape it to my garage door so he could pick it up at his lesiure.
