SXR Pump Question
Tuscaloosa, AL
OEM Stock SXR Prop is actually very good. Even better if you send it to IMPROS to get powertuned, cut back and repitched.
I raced with one for a year or so.
Shonuff
I've got the glow
Memphis
dude dump that stocker asap!!! what the hell is worng with you!!! hahahaha have you ever run a A.M. prop?
you have a badass hull with that turd in the pump?
Sorry, eastie, you're dead wrong about the 13/18 Skat Swirl stock SX-R prop.
Bay Area
so your saying a stock prop is better than a skat????? you guys are crazy!!!
im sure the stock kawi prop is ok an is great if your short on money! but dont tell me its better than a aftermarket prop???
Tuscaloosa, AL
No, what he is saying is that the OEM Props are very good. I raced with my Stocker, IMPROS Tweaked Stocker and then a Solas IMPROS Dynafly. The only advantage I got with the solas is it pulled harder right between Bottom to Mid. From Mid to Top it was not enough difference from my ski to my race partner who also ran a Stock Prop tweaked from IMPROS.
I know several racers who ran full limiteds who swapped back and forth from SKATS/Solas to modifed Stock.
Tuscaloosa, AL
The stocker is a Solas Swirl Stainless...so it really is an aftermarket prop already, unlike the garbage they put in SJs.
The 2008-2010 Superjet Prop is along theses same lines. The blades on the OEM SXR prop are thicker than a skat/solas. But overall it is a really good prop.
