- Henderson NV
I was wondering if you guys had any suggestions to help me figure out what is wrong with my 07 SXR. It has been running great for as long as i've owned it (3yrs) but it somewhat quickly (within a matter of minutes) started running really rough and weak/boggy. I ran it on the hose today and it is blowing a "black" oil/fuel mix out the exhaust, and it sounds like it is popping or misfiring. I did check the compression and it is good. Any ideas on what this issue might be, I don't want to start tearing it apart before asking you guys if you have any ideas what might be going on. It has the following engine mods:
wet-pipe
#zero lightened stock flywheel
aftermarket flame arrestors
Thanks,
Frank
wet-pipe
Thanks,
Frank
