below is copy and paste of some other relavent info
I had a Riva 46mm single carb manifold "kit" on one of my 62T motors and had a fun time trying to get it dialed in. It seemed to have about the same performance as the dual 44's that were on a R&D manifold (from 1/3 throttle and up), but the low speed (idle to 1/3 throttle) was the area of operation that I never got right. One of the issues was that the pop-off ended to be about 12psi, and with that low pop, the motor vibration (more or less,and frequency) at different RPM's would shake the needle from the seat and mess with my settings. The extra fuel consumption was probably because of this. The AM carbs some of you guys are running with higher pops might be less prone to this issue.
I sold the manifold, and bought another 46mm and made a set that (so far) meters more precise (higher pop-off) and offers better fuel economy. I really wanted to run a single for simplicity, but I couldn't get it to work right. For now I'm dealing with them (the duals).
Here it is from Art himself:
The 44mm Blackjack will flow more air than the unmodified 46 Mikunis. If you are not dealing with very big engines and not using total loss and race fuel compression then I question the need to go bigger than the 44's. For freestyle the 44's are more forgiving than the 46's when you don't have the big ccs, compression or building a full-on radical engine. If you had a properly set up normal big bore and your main concern was bottom end response then the advantage of the 46's would only be at midrange and higher rpms and you might not need that depending on your riding style.
If I build an engine that is say for example an 85 mm stock stroke engine and the customer wants the best bottom end possible with no concern about top speed I would do the 44 Blackjacks. You must remember that just because it is a 44 mm does not mean that it is not a high flowing set up. The difference between a set of stock 44's and a set of Blackjack 44's is night and day. This becomes more apparent the more modified the engine is. We do build engines using our 48.3 mm Blackjacks but the whole combo has to be perfect for the type of riding and the type of modifications for the end result to be the best. Even for most aftermarket cylinders running total loss and mag pumps and race fuel the 46 mm Blackjacks are hard to beat. The nice thing about the 44mm Blackjacks are that they are priced right. Just to let you know we have done stock ported 701s with pipe and impeller running 185 psi and the 44mm Blackjacks worked perfect with out loading up and offered great response even after idling for more than 30 seconds.
Thank you
Art
__________________
