masterblaster
X-H2
I got a brand new tbm flywheel,says 701 charging on the box ...when installing its REALLY tight on the key way and it doesnt seem to wana slide back it,even removing the keyway and putting the flywheel on it doesnt wana seat in all the way before it gets tight,I have a rad and stock fw that both work fine with this crank and keyway?
I went ahead and just used the ratchet to pull the fw in on the keyway,torqued it lightly,fw went all the way in and looked normal but now the motor feels kinda tight,I guess its pulling the crank up on the seal really hard? took it off and it didnt pop off with the puller like most do it just slowly pulled off? motor turns freely again,if this flywheel is machined wrong im going to be upset........any ideas?
