- JAX FL
I'm saying, shorted starter
How would I check? Cranks a majority of the time, and I can't seem to replicate what causes this. thanks!
Yes it's the bottom one. Will post a better pic tomorrow. I traded out the terminal screws with new ones, that may take care of it honestly.Just saw the video. Is your large ground wire the very bottom wire to the battery terminal. Can you get a better pic of your terminal and wires?
So a new one, what causes the engine to run out and not stop even when the stop switch is pulled? It was REALLY low on gas, so could this have cause it? Went to backflush, it was idling really high, revved it a little, still idling high so I decided to kill it....nothing. Luckily I always carry a screwdriver with me when flushing so I pulled battery leads and it stopped. Scared the crap out of me of course.
My understanding is that sometimes a lean fuel situation will cause this? Possibly because of how low the tank was. I don't believe there is an air leak anywhere. I rolled it in the ocean and not a cool roll either, a "I am a dumbass and hit a wave sideways, ouch that hurt" roll. But still rode for 10 min after that with no issue.
Hasn't done this before, don't think its an issue, but wanted to get some thoughts. Thanks!
Typically thats a free rev caused by and air leak after the carbs. If it ever happens again hold the throttle wide open and it will die. You tried hitting the stop button too right?
I would fire it up and see how it runs
Chens are fun! You gotta hit us up and do a water test! Lot's of mechanically inclined guys in our group, will easily pinpoint your problems.
Tomorrow the group is riding the Spot at 10:00 am!
Ran her today, runs great. Backwashed and started to run away, but just gave her some gas and it would go away like you said. No issues. But does this mean that there is a small air leak after the carbs? Only does it when backflushing through the pissers, haven't ever experienced it in water, or when not backflushing (although never run it long without a water connection obviously).
Not concerned about it, unless I should be.
