- Jacksonville Beach, FL
So electrical issue seems to be continuing. No more spark at the negative terminal, but no noise what so ever. Ran fine at Hugo, flushed and ran fine. But then it stopped making any noise when I hit the start button. Took start button apart for the umpteenth time, looks fine. Put back together, moved some wires around, and it started again. This was Saturday. Went down to check her out today, and no noise when hitting start. Could I be losing ground connection somehow? I assume I need to get a multimeter and start checking.
Its like I have connection and it cranks every time. Then somehow it loses that connection (or grounds out?) and won't make a sound. Wiring seems fine on wiring harness. Thanks guys. At least its a good winter project!
