PWC power requirements vs. efficiency
That's definitely something I've been discussing with the other folks working on electric PWC's. Mostly, the hulls that are being tested with are pretty efficient, especially when you take 30-50 pounds off of them and put a lightweight rider on for testing.
The pumps are probably the biggest inefficiencies right now. It's quite hard to take a pump designed for peak efficiency at 160hp and tweak it to be efficient at 55hp, or to make it work efficiently at a dramatically different RPM.
Since our goal is to provide a re-power kit for existing hulls, we're locked into providing a similar amount of torque for existing hulls and pumps. We've been testing with the worst case scenario (Blaster2, 155 pump, lead-acid batteries, very heavy test rider) to ensure that our target audience isn't disappointed. We want to make a drive system that will work for anything from a 440 to an SX-R and a Superjet to a Blaster2, with stock pumps (probably a prop change) and without hull changes for weight or improving plane-out.
Basically, we figure most enthusiasts either have a spare hull or two, or have access to them. While an electric PWC may be "green", it's even "greener" to keep an old hull in the water and in use rather than cut up and in a landfill!
We'll leave making new electric PWC's to someone else. (for now...)
Alan Kroeper
Revolt Hydrosport
