TURN YOUR IDLE DOWN, since you wont be able to kill the ski with the red button!
I put my ski in the water today and it still wont start. The starter is turning fine but it just wont catch. Fuel is moving in the lines cause I can see it returning to the tank. Fuel is moving in the primer. The ski has compression. So now I guess I need to check spark but I've got to look at a house with my wife so it will have to wait.
It almost catches up but only right when I let go of the starter and just for a split second. Things that I'm thinking:
1.The stator came from a junk pile and although it looked OK I guess maybe it's not.
2.The used MSD Enhancer I bought over the winter could be bad.
3.The jetinetics flywheel is bad somehow with the magnets or something.
4. New plugs but the plug wires are old.
5. I have no idea and I'm just brainstorming here. Can someone help me out with some opinions or suggestions. I REALLY want to ride this thing!
What readings should I get from a voltmeter from the stator and do I have to check it while starting it or what?
Or he could just plug the stop connector back in :redface:
open you electrical box, swap the 2 white wires.......
it can cause it to throw spark when you let off the start button.
what he said. do it NOW bitch!mfg:
joking
bk is right though. man that sucks, didn't you fire the ski before going to the water? man I start my ski at 3am or whatever time I finish it! I gotta know and I love the smell of 2- stoke in the morning! smells like- VICTORY!!!!
any of you young punks know what movie that was from? 2stroke is actually napalm.
how did you check the white wires? Did you swap them and try to crank the ski?? CDI's rarely die (talking about stock)Tried disconnecting the stop switch...didn't work.
Pulled the ebox and checked the wiring on the Enhancer....it was all wired right.
Switched the to a 61x cdi I had extra....still didn't work.
I'm not positive that the cdi is good since it came from the same box-o-parts as the stator, but I couldn't use my old 62t cdi because the connectors for the 61x stator were different.
I guess it has to be the stator. Time to pull the motor apart again.
