WFO Speedracer
- Alabama
I also had an issue like this with a jetinetics charging flywheel,the magnets were not strong enough to produce the required ac voltage,I knew right away what it was because thats all that I changed and it would no longer run,sadly you don't have that scenerio.You can do the screwdriver test against a known good flywheel but it requires you to remove the flywheel to do so.Check the output of the ac coil at cranking speed,if its low and the stator ohm readings spec out suspect the flywheel.
