The "lost" Phantom
Mn
Motor showed up yesterday and i got straight to work!
Bolted on intake and exhaust manifolds and built the ebox!
Got the engine perfectly aligned with NO SHIMS!
Tank is secured just need to finish the exhaust and run the water/fuel lines!
Should be breaking it in this weekend!View attachment 332077
View attachment 332075 View attachment 332078 View attachment 332079
Did you have to cut the corner off the water box to make it fit? I'm doing a similar project and trying to decide on a pfp water box or TNT.
Just4Fun
First World Problems...
Southern Oregon
Yes cut the corner off and cut 1" off the bottom. Keep in mind mine is sitting on top of inserts for a stock battery tray. You might not have to take the 1" off the bottom.
Just4Fun
Southern Oregon
So me not being a welder.... get a pfp box ? Haha
I think tnt makes a box with 45° notch in it. You could prob trade Tim if you haven't used yours yet. The pfp box is roughly the same height but they have to fit cause that's all califreestyle uses. You might be able to get away with a stock tnt box. I knotched mine cause it's sitting on top of 2 pieces of turf a 1/4 plate and inserts that stick up an Inch. There's also a 3/4 tube on the inside two inserts to angle the box to meet the stinger correctly. So the inside corner is raised 2" and is angling the box into the side of the hull.
Mn
I see. Have not got a water box yet. Buying used to save some doe. Like the welded on tabs by the way!
BoggedDown
Wes Boggs
Columbia, SC
Ski looks sick, i dont see how you could fit that waterbox in their without anything but a cart tank without modification to the box. Wouldn't fit my phantom with the 3g limited slip tank without metal on metal or metal on fiberglass rubbing and no padding. I had to go pfp box. Pic of the 2 side by side. Great job with the ski sorry to slightly derail but hopefully provide some help to guy asking or future builder.
Sent from my iPad using Tapatalk
Mn
Thank you!
