Did anyone ever get a pair of these boots? I am curious to know how they work. Thanks.
Brian
adidas zip/lace combos are the shizzzz!!!
http://www.weplay.com/Adidas/Response/
75$ and worth every penny!!!
Not much good for me, I need a size 5 in men's. Size 7's would be like clown shoes. Thanks for the idea, anyway.
Sharon
Sharon
uh.... yeah.... that would be funny looking...
Bozoette... lol
Well, after 4 months of waiting I finally have a pair of these new JetPilot Race Boots.
** My initial impressions **
1) Wow, they are really light.
2) *The sole is different when compared to the first design (prototype) JP7400 (look at original picture)
3) Technically, not a full ankle lace-up. But you can really snug the velcro ankle strap. Strap end faces inside, important for a stand up rider.
4) The lace feels cheap and may break easy.
5) Buckle that joins the 3mm neoprene sock and shoe together doesn't make much sense.
6) Rubber front toe protector is sano and is triple stitched to shoe!
7) Will the glued on sole delaminate?
8) Boot still fits well into my SJ foot-holds.
9) No metal eyelets.
10) Drain system will drain water but not sand.
11) Ankle bone "feels" more vulnerable.
12) JP size 10 fits just as my old Slippery "Large" did. If you can sometimes fit in the next 1/2 size up (street shoes), you may want to buy the next full size JP boot.
12) At an MSRP of $80 it meets my (max) limit of what a water should should cost.
13) Ohh, did I mention they are light :biggrin:
13) Tony Kwolek @ RivaMotorsports.com called me while on vacation in Cali to remind me the shoes arrived. Props to him for going above the line of duty and you guys should get with him next time you need PWC parts :biggthumpup:
* I think the reason why JetPilot took so long to release these boots is because they found the original (tan) sole design to be a problem. The production sole has 3 layers with an thick AVA dense foam pad glued to base and a rubber outer layer.
Original pre-production design:
Because every time I see a wrestling shoes, I picture 2 guys rolling on the ground. It gives me the heebie-geebies - J/K. Actually, I started riding with [SIZE=-1]ASICS but they didn't hold up. If I started using wrestling shoes now, my 8mm under padding would be too thin and my feet would rattle in the foot-holds....and I don't like the squishy feeling that the 24mm under padding offers.[/SIZE]why not just use a wrastlin shoe???
I hear ya. I have broken arches (flat feet) and after 2 days on the water (from 9am to 5pm), I get shin splints. Between my 8mm underpad in tray and these shoes, I hope to eliminate it. These new JP boots have very little arch support and it only comes from the sole insert (pad). The shoe is a little narrow but this will help with the support. The pad is 1/4" thick and has a waffle design bottom to help with its drainage system. The drain system is actually pretty cool by design.How's the arch support and insole 'cushioning'? My old feet hurt after(sometimes during) riding in wrastlin shoes or cheapo watershoes because there is so little support in the sole.
