The newly released JSTL Inc, TL ignition module...with a touch of OCD!
Canada
Dangit! I hate waiting lol If you need a test subject keep me in mind. Ive got a few months before I finish my chan. Im gonna hold out for this release
Those coils will be cheap and in the mean time you can just run the bigger coils. Please pm for pricing and availability
Off Site
Jonolove, your set up looks really good! Do you know the torque spec for the Jetinetics flywheel? I am just about done with my set up.
Thanks, Dave
Roseand
The Weaponizer
Wisconsin
Jonolove,Your set up looks really good! Do you know the torque spec for the Jetinetics flywheel? I am just about done with my set up.
Thanks, Dave
I can check in 5 minutes, my flywheel came with a sheet with the torque spec on it
Roseand
The Weaponizer
Wisconsin
Thanks, Dave
Torque spec is 85 ft/lbs
Sounds a little high to me..
Off Site
Here is my set up. I changed it up a bit. I lengthened the lead and ran deutsch connectors because I screwed up my crimps on the supplied fitting.
I am still in mock up stage so it may change once I drop the motor in. I will probably be able to get my cable lengths too.KIMG0004.jpg
#39
Australia
Can anyone tell me what magnets I need to order for my flywheel? And if it's not too much to ask, a link to where to order them with a part number?
Off Site
Burning the midnight oil. Hopefully I put it together right, new to the total loss.KIMG0020.jpg
Update: Denes caught a huge wiring mistake I made with two of the ground wires. Make sure your ground (pin A) on one coil is grounded seperately and run pin C (ground) to the head or somewhere on the motor. I had my pin C running to the 8 pin connector. They spell it out on the wiring map, just my incompetence. Lucky Denes caught it and let me know and I didn't wreck it.
Off Site
If you guys are running billet cases the profile is a bit different then the oem case. I had to chamfer the back of the stator plate. I kept having the crank bind up when fully tightened.
It took a bunch of tries to figure out where it was binding last weekend. I thought the ground wire was hitting it, I tried moving it, also ground some material (no luck), and finally painted the back to look for rubbing. Finally I figured it out. It is a real easy fix, just use a grinding stone to back bevel the center hole to clear crank seal lower lip.
I am real impressed with everything overall. Directon map is pretty straight forward, the price and customer support is immediate. I have never done total loss so it's been really cool to learn, so far so good.
The inner lip of the seal hangs out more on the billet cases. Back bevel crank hole to clear inner seal lip with your method of choice. I used a $2.00 grinding stone.
When trying to find static timing use stock cases and line static up with oem stator mark. Mark the center line of the cases on the stator plate.
Line up the center line on the billet cases and scribe a mark on the cases. Thank you to Kyle at Dasa for giving me idea for finding the static timing.
Yami-Rider
TigerCraft FV-PRO
Texoma
Any more people running these, any issues? Looks like a nice setup.
