Dustin Mustangs
uʍop ǝpıs dn
- Holland, MI
Updated again. Cough 'em up boys, there must be more...
wrong bolts we need 1.25mm pitch not 1.5mm
-Bed Plates, Port, Rear: 91287A181
-Bed Plates, Port, Middle: 91287A181
-Bed Plates, Port, Front: 91287A379
-Bed Plates, Starboard, Rear: 91287A378
-Bed Plates, Starboard, Rear/Middle: 91287A173
-Bed Plates, Starboard, Front/Middle: 91287A181
-Bed Plates, Starboard, Front: 91287A181
-Cylinder to Cases, long: 91287A373
-Cylinder to Cases, short: 91287A374
Ok, I took the bolt pn's off the list at least for now. I attempted to get the correct pn's but they don't seem to carry anything larger than a M8 with a 1.25 pitch. I find it hard to believe that there is such a thing and they don't carry it but who knows...
M10x1.25 is not that hard to find.
M10x1.25 Stainless steel - is.
Dustin,
If you see post #7, I provided the bolt information and took the measurements using a thread (pitch) gauge that was provided in a Craftsman metric tap and die set. I know the pitch is accurate. For the bolt diameter I used a both gauge thingy I bought at Home Depot, very similar to the picture below. The only thing that will very are the bolt lengths, and only that will be slight variations.
I bought new OEM bedplate bolts for my blaster because McMaster did not offer them at the time. I'm not sure if they do now. But rest assured, the pitch is 1.25 and the bolt is an M10.
On that note, thanks for compiling the list and getting others to participate. I thought it was nice to have the measurements available in the same thread as the part numbers, even though the McMaster #s were incorrect.
I will edit this and add soem later. I have found those quick disconnects like the CPC brand Jet Works uses to make their fuel and water restrictor connectors. Much cheaper than the ones in Hot Products but still a little pricey.
I also found the pinch on style Otiker clapms cheaper on McMaster Carr than hot Products.
I haven't ordered any yet because it is a little pricey and I am not sure if the color will match, but they also sell colored clear tubing that could be used for water lines.
DBR
