The Official McMaster Carr Part Number List
#ZERO
Beach Bum
Florida - U.S.A.
Here's a another Mikuni carb valve body screw that's the stronger more corrosion resistant 316 stainless steel with a number two Phillips flat head design.
Carb Screw, Valve Body Assembly, pack of 50: 91801A220
#ZERO
Beach Bum
Florida - U.S.A.
Those dowel pins for the cases, cylinder, pump etc. that state 6mm x 12mm: 93600A164 are wrong because they are 14.05mm in length. If you use them they will not seal properly without leaving a gap.
The Yamaha OEM dowel pin measures 6.00mm x 12.10mm actual size.
If you order McMaster-Carr dowel pins go with the 6mm x 10mm size because the actual measurements are 11.90mm for the 316 stainless and 11.75mm for the 18-8 stainless pins.
Here are the correct numbers to use.
93600A162 Metric Type 316 Stainless Steel Dowel Pin M6 x 10mm length pack of 10 for $7.74
91585A145 Metric Type 18-8 Stainless Steel Dowel Pin M6 x 10mm length pack of 25 for $7.75
D Slicker
Durham, dont forget it
Pottstown, PA
This is what I orderd so they are wrong?
Metric Type 316 Stainless Steel Dowel Pin, M6 Diameter, 12 Mm Length with the part number ending in 164 listed above?
I edtit my post to reflect this one.
#ZERO
Beach Bum
Florida - U.S.A.
Send them back or just grind them down some, because they're too long and don't work without sealing issues.
It's either a manufacturing problem or they're being mispackaged as 6mm x 12mm dowel pins.
I re-order both stainless dowel pins in the 6mm by 10mm size and they work perfect.
Dustin Mustangs
uʍop ǝpıs dn
Holland, MI
Good catch, I'll edit the main list.
Dustin Mustangs
uʍop ǝpıs dn
Holland, MI
Hmmm, I like what you have there minus the fact that you have to be registered with google to even view it let alone modify it. Is there a way to turn that off?
michael950
for me to POOP on!
Houston, TX
I ordered them, and they are rounded at the ends (tips are not flat).
Thanks for the correct numbers, I'll get it exchanged.
Per McMaster site:
How do I return or exchange something?
Simply send the items to:
McMaster-Carr
600 N County Line Rd.
Elmhurst, IL 60126-2081
You will be given credit upon our receipt of the material. There's no need to contact us, and we do not require a Return Authorization Number. If you would like to exchange the material, just return the items you don't want and place a new order.
michael950
for me to POOP on!
Houston, TX
I know there are at least 2 different sized dowel pins used on the SJ, anyone have the other.
More specifically, anyone know what is used for the pump to hull and pump to impeller housing.
2lick
Brap!!!
Limerick, PA
Hmm.. I will look into that i know int he doc files anyone can write thats what we do here at school to collaborate on papers....
I added a link to be public viewable but maybe you still have to have a gmail account to edit it....
I will see what I can do....
2lick
Brap!!!
Limerick, PA
how can 5200 not be in the list!!!!!!!!!!
67015A51
there are multiple sizes and in black and white..... this number will at least get you to the page....
Dustin Mustangs
uʍop ǝpıs dn
Holland, MI
So I finally placed my order. I am once again amazed at the speed of their shipping. My order was placed at ~3:45pm monday. The parts were on my doorstep when I got home from work the very next day and of course that is with standard ground.
I did get the viton (gasoline safe) o-rings for both the 1/4" and 1/8" coupler size quick disconnects. They only come in packs of 100, so for the time being I'm willing to hook people up with some of these for free if they contribute something useful to the thread.
I also attached a quick pic I took of some of the items on the list. It shows the screw porp valve w/ 3/8" ends on it, the fuse and fuse holder, the three different size quick disconnects (1/8", 1/4", and 3/8"), the tygon fuel line (3/16" and 1/8"), the braid reinforced clear blue cooling line, and the clear wire reinforced bilge line.
2lick
Brap!!!
Limerick, PA
Those quick connects....
The female half is identical to the jetworks one... but the male is aluminum.....
Just FYI...
Good find I wish I had no spent so much money on the jetworks last year..... but I use mine to adjust flow too....
You figure anything out to adjust flow with those???
Will the male end accept inserts?
dbrutherford
Parts Whore
Fairmont, WV
The Jet Works fuel line restrictor I have has a plactic release instead of the stainless steel one like Dustin posted. I would rather have the stainless release. It might have been that there wasn't any lube on mine but I was scared to death to take it apart the first time I disconnected the two. When I order me some new quick disconnects, I will try to see if it will mate up to the stainless version...
DBR
Ericfox
Do it twice?That's DooDoo
interesting note on the brass restrictors in the jetworks quick disconnects... either the brass or the aluminum (or SS or whatever the silver male end is made of...) oxidized a bunch without even any use... I think maybe it was just the brass in contact with the aluminum or SS.... I couldnt remove the little pill without removing the silver male end and sticking a bar inside it to tap the little pill restrictor out....kinda weird...maybe it is oxidized enough now that it will not continue to oxidize and stick in the future... not that it is that big of a deal, but it would be nice to change them by just tapping it out into your hand when making adjustments
