The Official McMaster Carr Part Number List
Q
QuickMick
Guest
3/8" hose to 1/8" NPT 45 degree elbo (brass fitting) 53525k46
3/8" hose to 1/4" NPT 45 degree elbo (brass fitting) 53525k47
these are hard to find at the hdw store. package of (5)
Reusable Nylon Zip Tie Cable Ties
6" to 1.5" dia .21 wide black 100 pcs 7134K2
8" to 2" dia .21 wide black 100 pcs 7134K3
15" up to 4.25" dia .30 wide black 25 pcs 7134K65
Zip tie cable mounts (mount under lip in engine bay with rivet)
for small cable ties .21 wide cables 100 pcs 7566K13
for larger cable ties .30 wide cables 50 pcs 7566K55
High Temp silicone hose 1 foot for Riva type 9 3.5" ID 5296K48
Q
QuickMick
Guest
I cant find the correct lord mounts for my pipe, where can I get them from??
1 1/2" wide X 1 1/2" long with stud on one end. I need (3). Largest I found in MMC is 1 1/4" X 1 1/4"
Dustin Mustangs
uʍop ǝpıs dn
Holland, MI
Yeah, it looks like they don't have that size. It might be worth a call to see if they can special order one. Factory pipe and Riva should also be able to get you some if that doesn't work out. Maybe not ideal, but I bet you'd be safe using the shorter one with a longer bolt and an extra 1/4" of those fiber washers stacked up.
I updated the list with the parts you listed as well.
Flash-FX
No Square..No Round..FX-1
Boyesen manifold O-Rings
9464K341 VITON O-RING, AS568A DASH NUMBER 034
The "round" ones for under the carb plate.
9464K141 VITON O-RING, AS568A DASH NUMBER 141
The "oval" ones for the reed cage seal (these seem a little big but they stuff in ok).
I tried the SEARCH function but could not find these #'s.
2lick
Brap!!!
Limerick, PA
Dustin.. add these to the list please!!!:arms:
WAB
salty nuts
coastal GA
Just went & ordered several items I needed. This is a great thread! :cheer:
Add: # 67015A51
Black 3m 5200 in big caulk-gun size tube
WAB
salty nuts
coastal GA
:veryhappy: :veryhappy: :veryhappy: :veryhappy:
Shipping time is simply amazing.
Got my stuff today, about 25hrs after I called in the order!
:cheer2: Couple of things to add to the list:
Item #: 5296k86
B-pipe blue coupler: $30/perfoot
Item# 85175k291
Turf underpadding - closed cell-neoprene/vinyl/Buna-N Foam Rubber sheet 1/2inch thick, 57inch wide, extra soft--sold by the foot. $14/per foot 57inch x 36inch = $55
Woody
Need to save my money!!
Long Island
Pipe for Dual-Cooling: 44635K232 or 44635K222, based on your discretion of how you're going to fit your tubes over it. We ride the ocean often and I need the stock bilge in addition to my Rule just in case....RIVA sells this for $30
**EDIT**- Correct Pipe sizes now. I think I'm going to use this for hooking up the stock bilge line, and the stock bilge pipe for running my dual cooling. Reason being is that you can't have a pipe with a 3/8" inner diameter and expected to get a tube with the same inner diameter over the pipe and having it stay on. The new pipes listed above are still bigger than 3/8," but not by much. Will keep you posted on how it comes out.
Mark44
Katie's Boss
100% one place
y
Item #: 5296k86
Item# 85175k291
WAB
FYI
I have tried that pad and over time the cell structure breaks down and the holds a lot of water.
Mark44
Dustin Mustangs
uʍop ǝpıs dn
Holland, MI
Do you know of one they offer that works better by chance Mark?
Pipe for Dual-Cooling: [FONT=Arial,Helvetica,Sans-serif][/FONT][FONT=Arial,Helvetica,Sans-serif]44635K242[/FONT]. We ride the ocean often and I need the stock bilge in addition to my Rule just in case....RIVA sells this for $30
That's a good find, and I'm shocked you got a direct link to work. Did you just copy and paste the link off the product description page or do you have some other trick up your sleeve?
Mark44
Katie's Boss
100% one place
O
Sorry I don't. I have tried many different kinds and I have found that even the closed cell EPDM break down the cell structure over time and absorb water. I hate to say it but I have not found anything better than Hydro turf padding.
The last EPDM I pulled off my ski was saturated with water and weighted about 4 LBS.:Eyecrazy:
This product does however make for a very good hood seal.
IMO
Mark44
Woody
Long Island
i think it worked because i used the picture from the link... no other tricks...i was surprised too that it worked
Woody
Long Island
Woah...just received my pipe I ordered, obviously I did something wrong because that is not the correct part number. Will figure it out and edit original post later tonight.
**Edit** Correct part numbers listed in post above.
Pipe for Dual-Cooling: [FONT=Arial,Helvetica,Sans-serif]44635K242[/FONT]. We ride the ocean often and I need the stock bilge in addition to my Rule just in case....RIVA sells this for $30
Dustin Mustangs
uʍop ǝpıs dn
Holland, MI
I've never done this before, but I'd imagine something with an 11/32" ID would work. That is the drill bit size recommended for a 1/8" NPT tap which is the best thread size for 3/8" barbed fittings. I'd also imagine aluminum would be easier to work with (and cheaper) than stainless but, like I said, I've never tried this before. You may also be able to find a pipe with the 1/8" npt threads already on it (male or female) but it would need to be the correct length. Good luck and keep us posted.
2lick
Brap!!!
Limerick, PA
Some thing I just got...
Some of them are not on the list and others I thought some might want to see a picture of....
  • 90278A321 Metric 18-8 Ss Precision Socket Shldr Scrw Hex, 5mm Shoulder Dia, 5mm Shoulder L, M4 Thread
  • 6658K16 Metric Sae 841 Bronze Sleeve Bearing For 12 Mm Shaft Dia, 16 Mm Od, 20 Mm Lg
  • 91585A145 Metric 18-8 Stainless Steel Dowel Pin M6 Diameter, 10 Mm Length
  • 2988K311 Stainless Steel Metric Ball Joint Rod End M5 X 0.8 Rh Female Shank, 929 Pound Load Capacity
  • 9464K341 Viton O-ring As568a Dash Number 034
  • 9464K141 Viton O-ring As568a Dash Number 141
  • 6436K61 Two-piece Clamp-on Shaft Collar Type 303 Ss, 5/16" Bore, 11/16" Od, 5/16" Width
  • 47245K27 Diaphragm Check Valve Nylon Body/fluorosilicone Diaphragm, 1/4" Barb
  • 74965K63 Moisture-seal Polyolefin Heat-shrink Tubing 1/4" Id Before, 1/8" Id After, 48" L, Black
  • 74965K65 Moisture-seal Polyolefin Heat-shrink Tubing 1/2" Id Before, 1/4" Id After, 48" L, Black
  • 74965K61 Moisture-seal Polyolefin Heat-shrink Tubing 1/8" Id Before, 1/16" Id After, 48" L, Black
  • 9845T103 Aluminum Hi-misalignment Spider Coupling Hub 5/16" Bore, 3/4" Outside Diameter
  • 9845T13 Blue Shore 85a Spider For 3/4" Od Aluminum Hi-misalignment Spider Coupling Hub
