SX/SXi/SXi Pro the reconstruction of my first ski! ( 750sx)
Reglassin
started fiber glassing on Thursday and finished today. patched all the wholes and fixed all the cracks and rebuilt the ride plate mount. we glassed in a peice of 1/4 inch alu. where the ride plate mounts to drill and tap into. and i fixed my handle pole. (it was flopping in the wind) so now i gotta sand and fill, sand and fill, sand and fill. then gel coat and ill be all done w the fiber glass and then im thinking a paint job. then i can put it all back together. and by then it might be warm enough to ride! :brap:
same out good. not too much sanding...
crack fixed
alu. set and foamed in
glassed
and my paint scheme im thinking about doing.
Heads up, if haven't already drilled/tapped the ride plate bed, you can drill/tap for a SXR/SXI Pro pattern. You'll have more modern rideplate options obviously.
AWESOME WORK by the way!
pump rebuild
got my pump rebuilt kit and new used shaft and put my pump all back together. no all i gotta do is paint and put it all back together and im ready to go! :bananapowerslide:
old/ new
I was able to retap the threads on my stat trak impeller! :arms:
ready to go! but i gotta paint and gel coat first... to cold now
so its coming along nicely! mechanicly everything is fixed. bot its just cosmetic stuff.
got my trailer all set up today. installed new tail lights. flipped the axle, to lower it. and got new wood and bunks for 2 skis. all set and ready to go!
before
after
bare A$$ naked
im just gonna keep updating this build!~ even if noone cares anymore! :biggthumpup:
got her completely striped down to a bare hull. bottom all prepped for gel coat and starting sanding/ preping for the top.
NW PA
Careful with flipping that axle, make sure it isn't one that has a factory bent axle, it should have a negative camber (required for good tracking down the hwy). Otherwise looks great! I'm ashamed to say you beat me with the free trailer, I still have none.
ya the axle has been re welded.. so im sure any factory bending has been messed up or is no longer there.. haha
no one can reapply when you have had any up dates for a while , post pics of progress etc and everyone will get interested :-}}}
so you painting or getting a wrap done ?
haha alright ill have to post more often. im gonna paint it. got a hlpv gravity feed spray gun so im gonna use that. :) its gonna be a learning experience. then i gotta do some paint on my jeep. so im gonna go through the learning curve on the ski.. haha
put some new lights on my trailer and i had to fix the trailer lights on my jeep. (guy before me did a crappy install) and i added a new "flasher" blinker relay... all set and ready to go! ( hooked up to my jeep here) my pride and joy! im 16. so im learning how to pull a trailer.
vitalikol
Jetski-Snowboard
Pennington,NJ
Pulling is not a problem. Just remember to go little bit wider on turns, so you clear curb. It's backing where it's get interesting. Get some practice on empty parking lot to get filing for it before you go to local rump, so you wouldn't emberece yourself .
ya thats my plan. get some practice in so i dont embarrass my self at the launch ramp and become one of those guys that i laugh at. haha
