the trivial complaints thread
Iowa
So we are really close to finishing up the house. A couple weeks ago i rented a trencher and cut the trench for the power to the house from the pole. Then a delivery driver for the lady next door drove across my trench and caved it in. Now i had to pay to have it dug back out and then to top it off i fell into the trench last night and tore my leg all to hell on a board laid across it.
Where's your build thread?
Tuscaloosa, AL
My first complaint and it's a good one!
1: Anything to do with SXR Dry Pipe removal. (Had to change leaky orings)
2. Find out the pipe is cracked
3. Try to remove prop from pump and sheared the pump shaft!
This all happened on the same night. How could the pipe Crack with all that reinforcement from the factory?
Sent from my SM-G935F using Tapatalk
Those pipes are notorious for cracking. A lot of weight up high. Wow on the pump.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Guam
I welded it up, but I'm pretty sure I'm done with dry pipes. The metal had a lot of surprises, so it was hard to get a clean weld.
2 days ago we had really high winds and my neighbors trampoline blew into my deck railing and broke some pieces. The thing had to have traveled about 150 feet and up a hill to get where it hit. I'm sure I will never see a penny from them to fix my railing, and they will probably just set their tramp back up all bent and broken.
My neighbors set their trampoline back up yesterday... I'm not sure if they realize they live in Michigan and there is still 3 months of winter left, and probably 5 months until the weather will be decent enough to use the thing.
