XS_Power
teamxscream.com
- Clearwater, FL
The XS1200 will be released in early 2011. The web page below will outline the results of hundreds of hours of research and development on this highly anticipated project. Our XS1200 Development web page has photos of some custom engine components.
Follow our progress here: http://www.xmetalworks.com/XS1200.php
The engine features modified Yamaha 66E cases with a custom manufactured stator plate allowing the use of 62T style MSD electronics. The MSD TL ignition will bolt on with no additional modifications required. Carburetion will come from dual 49mm Full Spectrum carbs with a custom XScream intake system. No exhaust adapter is required for 701/760 style exhaust systems. This engine uses an 84mm billet crankshaft designed, built and balanced specifically for the XS1200 (Stroke 84mm x Bore 94.5mm/95mm).
94.5mm Bore = 1178cc
95mm Bore = 1190cc
We will be adding photos and updating details on this web page as the project moves closer to completion.
Please feel free to contact us with questions or to reserve your XS1200.
95mm Bore = 1190cc
