- Grand Rapids, MI
You need a strap with a buckle for the battery. It gets threaded underneath the tray.
Why did you go for the HUGE exhaust tube?
Because he said yours was a PITA and he really prefered not to do it again.
you guys I hate Chad and Matt now with your fancy Superfreaks. jealous. jealous. jealous. dammit. I quit!
oops, did I just say that out loud????
Seriously, congrats to both of you - and please please please can I bum a ride next time we meet up? :fingersx:
Got some sanding and filling done yesterday. Also mounted my pole and spring. It actually worked quite well and was pretty easy to install the spring. Only one problem......the spring worked too well! It's hilarious, you let go of the pole and it shoots all the way up. Guess I need to trade my Blowsion spring for a stocker.
Hey you freaks.....question.....in the box with the bolts for the pole brackets there were two extra bolts. What are those for? There are also a lot of extra washers and I'm not really shure what they are for. I am assuming the big washers are for the back of the pole bracket bolts?
Do you plan to just make a metal plate for where the spring is resting on the ski? Hard to tell exactly what is going on from the pic, but my idea was to just make a plate for that area if I decide to run a spring. In all likelihood I expect I won't like the tight handlepole and will want to go back to a sprung setup.
Glad to see you got yours, Chad! Tell Paul to bring his new JM big bore over to try in your freak.
I actually ended up bending my spring last night to take some tension off it. I think it will work perfect. All I can say is I hated drilling my breather holes for the pole through this pretty new hull. scary!
