i would up the torque on the girdle studs to 40 ft lbs
use an msd enhancer just to get a slightly better timing curve-more retard up top
make sure no less than .005 piston to wall for dual cooling with cast piston
.006 with forged pistons
try lowering the popoff 3-4 lbs with spring or next size needle valve=overall richer jetting
edit: after rereading-go to a 2.0 n&s
