849tigerbotkv1
formerly ihate5mphzone
- where i can ride 2stroke
Gen1
Gen1
Ktm don't get me wrong but I don't see why kawi will take longer?
Esp that the bottom of the hull is based off a kawi
The hull is ment to be glued together that means all the driveline setup is done?
Yes pretty much when you put it hat way but
Its been 85% complete amd glued together for a while now that means thats all done?
Just to clear everythingNo that means the hull was 85% done with Yamaha setup before the down payment was made. Now before he bonds the 2 decks, he needs to adapt the bottom deck to accept Kawi motor mounts, carrier bearing for bulkhead, and pump mounting as well as pump tunnel and shoe. Not sure how many Kawi setups will sell so it sounds Tony is really bending over backwards to do all this work. If it were my business I would have said "no, buy Yamaha parts" but it's not. I just think all details should be laid on the table. The fact that he's setting it up for Kawi means it'll take a lot of extra time so maybe he shouldn't complain.
