- ireland
Hay folks,
Im starting to surf ride my waveblaster,myself and a few friends have got the blaster bug in southern ireland!
We all seem to have trouble in dirty white wh surf especially,too much water onto our leads and into the carbs is or problem,im sure theres being plenty of posts,and plenty of fixes,im so comfused over this i dunno where to start.
From my reading i thinkimg MSD leads plug,plug caps,retainers and the big expensive enhancer!i am also without a bilge pump,what you guys recommend,yamaha fitment or universal??and which switch to go for??
Were running std air box covers,which we found worked better than aftermarket filters,duck bill drains which do drain the water once injested into the hull,(just not quick enough)and discovered sponges lined in the hull soak up the water!!
Some advice in the next directions we should take would greatly be appreciated!!!!
