TR1 vs TR1 HO
Bay Area
Alright been looking into this and not much info I can find... What I THINK I know is Yamaha has a tr-1 and a tr-1 HO the HO is in some of the VX models and claim 130HP. 20hp gain sounds great... All I've been able to find is they have a different exhaust manifold and maybe a different map or just higher RPM limit....
Only info I have found was either Jetboat forums and very few things on GreenHulk.
Do any of the X peps have any insight or info.
Once again this is all just info I have tried to find and could all be false! lol
Big Kahuna
Administrator
Tuscaloosa, AL
I think pretty much the same. Manifolds and tune. Guess Cam could be different.
waxhead
wannabe backflipper
gold coast
I looked into this a lot and had the vx manifold to go on. We looked at all the part numbers and the only change we could see was the exhaust system. Im guessing t tune was different as well
IceRocket1286
Metro Detroit
What year VX manifold? The VX manifolds I looked at were all 4 cylinder but I didn't look at every model year... The ECU & manifold part numbers are different between the Blaster (HO) and Superjet. That's as far as I got.
Bay Area
i found more info on FB... to show the difference of the manifolds side by side, Yes the HO is bigger manifold but does not look like direct bolt on. I might just do the "ribbon" delete on both the intake and exhaust with a tune and call it a day.
socal750
Socal750
beaumont CA
You have to cut the tail piece off,vx is more of a long tube header,running it straight piped with sibler tuner,riva intake,impros prop,wcot plate and toploader…wakes it up on the bottom but no top speed gains
