Bobby..
how far up inside the hood do the tubes go? do they oriented straight up or do they make a bend towards the front or back the the hood?
I have noticed on a couple of very low profile hoods that they tend to take on water quicker (when upside down) than hoods that are taller.
difference between the 2 is the way the hood tubes travel up into the chamber..
lower profile hoods will enter the liner, travel up a couple and then bend towards the rear of the hood
taller hoods have a tube that will travel right up to the top of the inside of the hood..NO BEND
I have noticed on both my REV hood it will take on water quickly if the boat is upside down...Nicks WCF hood will do the same
My fx1 hood will float WAY longer upsdie down....as will my F1pro hood on the same boat..
the REV and WCF are very low profile....the fx/f1 are much taller and have tubes that travel straight up at least a solid 6-7"
this becomes interesting when you take into consideration pole choice....
Most of the aftermarket aluminum poles will keep the boat upside down if flipped over.....a stocker will right the boat due to the foam
