retroicon
XX-xx-XX-xx-XX
Hello again all,
I'm staring a new thread here because, being totally honest, people don't read the thing before posting so I'm starting fresh. After 2 pages, no one reads a damn thing... me included.
So here's what up.
4mm Stroke, 1mm Overbore
Dual 46mm Carbs
MSD Enhancer - NEW
JSS Coil - New from JSS
Zero Lightened Flywheel - New from Zero
Stator - Working when last used
Blaster Mod Pipe
RPM Racing Girdled Head - 205 compression in each hole
Before I continue, I want to be as clear as I can. The Carbs are not the issue. The carbs, fuel lines, fuel line routing, etc are NOT the issue. I've rebuilt them numerous times, they're perfectly clean, all passages flow properly on both carbs. I've eliminated carbs as the issue. They're solid.
The engine passes a leakdown test, the fuel lines are brand new, the engine had just undergone a fresh rebuild. New pistons, rings, fresh hone.
The motor fires, and both cylinders are producing spark. It sounds fine at idle when not under load, and will run at idle in the water under load.
When I pull the throttle, I can tell something is off. Acceleration is slow, it kind of feels like what you'd get on an old Waverunner 3 with a 650 in it, if you remember how those feel. Very slow take off, and feels like it's maxing out in the 25-28mph range.
On deceleration from WOT (which is 25-28mph) I can hear a detonation ping multiple times. This only happens on deceleration, not on acceleration.
The pictures I'm attaching were NEW plugs. I went WOT for about 15 seconds, and shut it down and coasted to shore before taking these pictures.
The front cylinder's plug is on the left, and the rear cylinder's plug is on the right. And yes, those are small droplets on the front plug.
At this point I feel like it has to be electronics.
I'm sure I put the stator plate in the right way, and I'm 99% sure I lined up the timing to be stock. (at this point, I can't be 100% sure because it's running so bad)
Any suggestions based that are NOT carbs.
I haven't checked the electronics yet because I haven't had the time. Finally, I'm not a rookie when it comes to this stuff, I'm just not sure on this one since I've never seen anything like it before. It's typically either a go or a no-go on the electronics. I've been riding for over 20 years, and have always been the wrench on my machines.
-G
So here's what up.
Dual 46mm Carbs
MSD Enhancer - NEW
Blaster Mod Pipe
-G
