tmetz
Camp Superjet!
- Naples, Florida
Definatley going to try this trick tommarow...
I think its time for dual bildges?
TURN SUB: a cool-looking, super easy trick to do. Start out at quarter throttle or less (5-10 mph), put your right foot in the front left corner of the tray up against the dash and put your left foot in the water beside the boat like you're doing a leg drag. Lean forward and crank the bars left and drop the hammer. you'll corkscrew straight down and if you keep it pegged, you can go deeper than a regular sub by far. The neat thing is that on the way down, your pump will do a sweet fountain and any onlookers who are unfamiliar with standups will be held in worshipful awe and reverence of your "skill." especially easy on the nose-heavy SXR. So if us lowly Kawi riders can manage it, I'm sure it will be a snap for all you high-and-mighty SJ riders
0 degree bars/ shorten pole helps a ton. It was harder on my stock bars...
great straight bar setup:
http://www.xmetalworks.com/products/xscream+adjustable+steering+system/73
It doesnt help when I can sit and float on top of the ski standing while its not running... i cant get it under
TURN SUB: easy on the nose-heavy SXR. So if us lowly Kawi riders can manage it, I'm sure it will be a snap for all you high-and-mighty SJ riders
