Hello,
I found this forum recently and I saw some folks here have ran the seadoo engines on the Zelltronics CDI and I figured some of you may be able to help me. I have an old 97 GSX and I had a very erratic timing issue and it turned out to be the MPEM. I did a pretty cheap setup with a low cost aftermarket CDI unit. I got the ski to run off the trailer and in the water which is great. Currently my problem is the idle is very unstable in the water and the engine is unstable hesitant up to midrange rpm. At high rpms 4k above it absolutely flies. Since the CDI unit is not programable i'm thinking the static angle timing is off. I read on some threads it's about 41 degrees on the 787. I noticed my line on the mag cup starts to trigger the pickup coil when the piston is at TDC. Do you think if I redrill the 6 holes with a 41 degrees advance I can solve the timing issue at idle to midrange?
I can post pics of my setup.
