I was hoping someone who has installed a quick steer system could give me some help.
I installed a UMI steering system and want to use the outside hole for the fastest steering ratio.
I turned the stop in the handlepole sideways. When I turn left it hits the stop. When I turn right although it doesn't hyper-extend the cable, it hits the limit of turning when the plastic nozzle hits the aluminum reduction nozzle. This is probably not good since it would still strain the cable when slamming it to full lock/turn instead of just bumping up against the stop.
If I adjust the cable to get it so it travels the same to each side I'm afraid that when the bars are straight, the nozzle won't be straight and it will turn even thought the bars are set to go straight.
What's the trick to get it adjusted right?
Should I instead use the next slowest hole, and modify the turn nozzle?
If I do use the outside hole and grind down the stock chin pad to clear the pole will I break the chin pad doing hood tricks?
Thanks for any and all input.
Details: 2002 SJ, Stock pole/chin pad, UMI plate, 0 degree UMI freestyle bars.
