ProSouth
Seriously, Don't be a dick.
- kawasakis suck
TRU DAT... ^^ i've "heard" of some nice 701's out performing 760's and so on and so forth. i would def. ditch the kawi driveline... that outta stir something up
Do you know what Polaris engine it based offBrand means little once you get to full custom builds. With the right builder you can build a kawi based motor that performs just as well as a similarly built yamaha based one. Just for example, EME engines are based on a polaris engine. Yamaha desinged their stock engines making them better for freestyle out of the box, but once you go to full custom builds, the original design is nearly erased entirely, meaning starting with one over the other means nothing.
All the yamaha is best stuff comes directly from the "buy a superjet" mentality. If everyone is riding skis that take yamaha engines, why bother to develop something else. Doesn't mean it is an inherently better design, just means its in higher demand.
At least not a gen 1, seeing as noone makes a lightweight gen 1 hull - that i know of, there were rumors of people developing one, but I haven't seen anything able to purchase. But I would bet that if you gave 20-30k to bullet or trinity they wouldn't have too much trouble building you a Gen 2 that flatwater flips. Problem is noone has had the motivation ($$$$) to build one, anyone who spends (or has thier sponsers spend) that kind of coin on a ski is getting something that is built for competition (aka pole ski) and an X2 is never going to be competitive in freestyle.
I have buddies that build carbon fiber/Kevlar chassis for sleds, I will have to ask them how hard it would be to attempt to build a hull
Really , I believe Jeff Kamikaze Kantz would highly disagree with that statement.
I have never heard of these engines. Who owns them?
I just base my assumptions on my engines and people I ride with. I have run 3 kawi engines in the last 2 years and all have issues, whether I build them or I have bought them off people have built them and they all have issues. I build one Yami 701 and it runs awesome even when the jetting is off. Then my buddy improves it and it runs even better. My argument is Yami built a solid engine more then 20 years ago and every aftermarket builder bases their engines off of it nowadays.
Kawis are great entry level but step into a Yami and it's night and day.
Its all relative, I build Yamaha engines at a rate of 10 to 1 over Kawasaki engines or Seadoo engines, I have built two this week, one 701 61X and a NPV 1200. Does that mean Yamahas are junk , no it means they have oil lines that come off and power valve failures.I have never heard of these engines. Who owns them?
Yamaha is not an innovator , I used to work at the dealership and was amazed at the technology that was rehashed over and over again. I will give some examples, first Yamaha four wheeler was a Yamaha 225 DX three wheeler frame with pieces welded onto it to hang two more wheels on the front, absolute junk really. First Yamaha watercraft WR500 was a converted outboard engine with pieces added onto it to turn the intake and exhaust and make it fit into a watercraft, good skis slow as hell but at least it was reliable. Yamaha Blaster four wheeler, a DT175 engine stuffed into a crappy frame to make an even crappier four wheeler. Yamaha Radian, a Seca 550 engine and frame with different bodywork. Yamaha XL series watercraft, waveventure hulls with new plastic bodywork, seat, grab handles and steering cover to make it look like a new boat, nothing new there same old technology. Yamaha VX series, MR1 motorcycle engine stuffed into a watercraft with gear reductions added to bring the pump rpms back down to 7000, the engine still turns 10,000 rpm and the gear reduction sounds like a Muncie rockcrusher four speed transmission. Yamaha 6M6, 61X,62T,64X engine series, engine started out as a 650, larger bore added for 701, larger bore added again for the 760, it works and it works well but its not innovative in the least.
